kaggez
January 16, 2023, 6:55pm
If you trigger a Timecode cuelist with a macro it gets triggerd as paused.
It only happens to a timecode cuelist. Not a normal cuelist or override
Happens bolth on 4.6.1230.0 and 4.8.124.0
Ive recorded a short video to show the issue: Onyx timecode issue - YouTube
Running 4.6.123.0 But also tried on latest release
Mike
January 17, 2023, 9:47am
Does a timecode run in this moment?
If not, it’s waiting for a timecode input in order to run.
kaggez
January 17, 2023, 10:33am
#3
Yes its running.
And if i trigger it without the macro it works fine.
Mike
January 17, 2023, 11:15am
#4
OK, I will test this in a free moment on my end. I think that with or without macro it should run in the same way…
kaggez
January 17, 2023, 11:29am
#5
Yes thats is what i expexted as well.
Mike
January 17, 2023, 2:00pm
#6
OK, checked on my NX2, launched from macro a timecode cue list goes to 1’st cue and pauses.
When launched directly without timecode, it goes…
Using a macro go cue xx forces a pause. The same as using GOTO Cue XX from the command line.
This is by design to be able for an operator to jump into a specific cue and stay there until timecode is re-armed by hitting GO.
Otherwise you would be unable to jump to a cue (e.g. some emergency or actor missed something) as the running timecode state would instantly flip back to the correct cue based on the timecode stamp.
kaggez
January 17, 2023, 4:21pm
#8
Is there another way for a midi macro to trigger a timecode list?
dont fill the cue # slot in the macro editor, simply leave it empty.
kaggez
January 17, 2023, 5:10pm
#10
Oh Dident realize that i coud leave it empty! Thanks so mutch
