Timecode show stack
Today my show stuck at 2 sec, i tried to trigger cue manually but pan and tilt fx in all cues was not working as well as int fx. I triggered it by art net timecode generator just like i always did . Before it was working without problems and i used same equipment, pc, software and onyx show file.
Also sometimes i see that fixtures don’t have pan and tilt fx but timecode is not stuck like in my first case, movements were recorded in cue and only after restart it was running fine.
I got timecode stuck only 1 time from 5-10 times running show before.
Did you have time to look at DMX output to see if it was not fixture related ?
No, it was live show so i had to improvise instead. And i not really understand how it can be fixture related because it works always perfect when i use common cue lists, also i have macro for cleaning all previously launched cues for full blackout before show so nothing was interrupting it. As i said it was first time i got this issue so it was very strange.
I will try to reinstall windows, maybe it will help
