Can you add the chance to activate “timing " directly from the stored preset ,without creating the cue!
This would make busking a lot more faster and spectacular to use ,something in the " preset properties activate stored time on selection”.
Thanx anyway!
You can work with the global fade time.
try to do ,1 thru 5 thru1 in live using global fade time! please let me know!
Set 2 tabs with the time that you want, and other with 0, apply the global time time when you need it and then comeback to 0.
Giancarlo, the other way to do this is to use F-keys and assign them ‘Live Time commands’ and add an F-Key window in your preset page.
