Hi guys,
I setup TouschOSC without any problems but now I’m looking for a way to trigger a cuelist (on playback bank 1, fader 3) remotely from qualab through OSC. Does anyone know a of an OSC command list?
Thank you so much
THomas
Hi guys,
Thank you so much
THomas
hi Thomas
copy to the playback Buttons from there you send an OSC comend
for image button 64 OSC              / Mx / playback / page1 / 63 / go
hope you can do something with it
Thank you so much Tibbe.
Unfortunately it still doenst work. If I use the same command from Touch OSC it works fine. If I use the command /Mx/fader/2202 0 from Qlab the grand master goes to 0 so the connection works.
Can you use MIDI? I have used MIDI to trigger the Go button in a cuelist, is really simple. You would need RTP in your PC so you can use MIDI over IP
Thanx for your reply. I have indeed got MIDI over RTP working. as well as the OSC by the way. I can now control the console in so many ways, it’s perfect!
HI I FIGURED IT OUT AND GOT IT WORKING!!!,
You actually helped alot to steer me into finding the solution.
to press go from Qlab on Bank 1 , playback 1 is:
/Mx/button/4201 1
Commands list is here.
Shout when there is more
