I created a new showfile and patched a few fixtures but when I select the fixtures, open 2d plan in edit mode and select add, the popup shows ‘0 fixtures selected’ and the place fixtures button is disabled. If navigate to fixture groups in the add fixtures pop up i can select groups and the place fixtures button but am unable to draw them onto 2d plan. The ‘Touch here to cancel’ still works though. The same goes for placing objects, the only thing i can do is cancel out.
I first noticed this on 4.6.1218 and upgraded to 4.6.1219 in hopes it would fix it. I was able to add fixtures to my existing showfile, which I have upgrade from 4.4.1193. I have tried restarting the show, a full PC restart , recreating the show and upgrading to 1219.
I have tried with the following profiles:
beamZ LCB252 Bar 252x RGB LED 48 Channel
beamZ LCB803 LED BAR 80x 3-in-1 48 Channel
Blizzard LB-Par Quad RGBW 4 Channel
Cameo Studio Mini Par Q 8W 7 Channel
ADJ Mega Bar Bar RGBA 34 Channel
So far this is the only PC I have upgraded from 4.4 so I haven’t tested on a different computer.
