hello, is it possible to record and merge the weight value info from a part of a multipartfixture in a dylos zone, to the default value preset of that fixture in that zone? or is this only be recordable as a cue?
thx.
thx.
Hi @deflost
The default value of Modifier parameters (Effect, Fade, Delay, Weight) cannot be edited.
Therefore, to create your own defaults for weight parameters, you could record the required values into an Override playback for example, which can then remain active.
that’s a very nice suggestion. thx.
