White flash button
Hello! I can’t figure out how to make a playback that sets Intensity and RGB channels to 100% with fade and release times, without releasing other playbacks with intensity and color values — but instead overrides them.
Sure, I can set every Intensity and Color playback to stay alive, but this doesn’t feel like the right solution, because at some point all color playbacks will be ON, and you’ll have to reapply them manually.
Please, help.
Software Version: 4.10.1271
NX Console Type or PC OS Version: PC OS Version
To create a white flash button, select your fixtures, set them to full intensity, and then set their colour to white. They will probably be white by default. However, manually adjust the fixture’s colour parameters anyway using the encoder wheels, so that the values are brought into the programmer. Then, tap RECORD, tap a playback’s button, and then choose “Override”. Now go into the options of this playback, and configure the “Flash Timings”, to give you a fade in and a fade out (Attack and Decay). Then, in the Function Assignment tab of the options menu, make sure you enable “Timed” for the button you wish to use as your flash button.
Now, you can “flash” your white playback over the top of exiting playbacks, and the flash timings should run.
