https://obsidiancontrol.box.com/s/qbqw92l907kaz33ned7xn4qsshtcp9mg
Release notes for Onyx
(C) 2019 - Obsidian Control Systems
4.3.1181 (11/12/2019)
Fixed EDIT CUE not activating UPDATE context
Fixed DyLOS engine crash at startup
4.3.1180 (10/12/2019)
Added vertical scroll to DyLOS text generator
Added bounce, beat and random playback modes
Added Clear/Load to (right-click) popup menus in Zone Composer
Modified MOVE MEDIA semantics to SWAP in case of conflicts
Fixes and (performance) improvements:
- Text (zoom) improvements
- Improved labels for better consistency
- Removed grouping tools from top of Zone Composer
- Fixed Factory Effect/Generator/Shape thumbs in library panel
- Fixed loading a single media file into multiple slots in one command (loading only the first)
- Fixed USB DMX devices not sending data beyond universe 64
- Fixed inability to restore internal DMX devices to defaults when not all ports are attached to Onyx
4.3.1179 (29/11/2019)
Added text generator to DyLOS
Added M6+ (upgrade kit) licensing
- Restored Martin LJ license unlocking
- Display progress while importing/exporting media
- Improved dynamic channel layouts
- Improvements for adding DyLOS support to show files
- Fixed fixtures with patch suggestion part (external dimmer, etc) being presented as multi-part fixtures in 2D plan
- Fixed Programmer and Cuelist Values not handling zone renumbering correctly
- Fixed loading large show files (+17GB) on consoles
- Fixed a crash when FX-linking zone channels
4.3.1177 (08/11/2019)
- Provide load/default shortcuts on parameter group popup
- Show generators in library breakout view
- Fixed artifact in Line effect shader on DyLOS
- Fixed renumbering multiple ID numbers of DyLOS zones skipping 4 ID’s every following zone
- Improve media saving speed
- Fixed Programmer and Cuelist Values not handling zone deletion correctly
- Fixed DyLOS engine crashing on fixture(-part)s that don’t have any channels viable for pixel mapping (being mapped in a zone)
4.3.1176 (01/11/2019)
- Media resynch button now supports different scopes
- Creating new show now shows an option to resynch media (map) on the system into the new show (default OFF)
- EDIT can be used as well to rename library folders/slots
- Zone page selection not correctly updated when resetting to recorded settings
- Multiparts placed in visualization mode on the 2D stage do not show pixel information
- Newly added fixtures would not be pixel-mapped to until restart
- 2D Plan (Onyx) crashes when enabling/disabling zone preview
- Async import of media files (improves responsiveness)
- Some DyLOS shaders don’t work in Release build (like Line Effects)
- Fixed Pan/Tilt invert/swap
- Delay OSC playback control if no license has been found
- Show descriptive labels for some DyLOS parameters
- Gobo images with - in filename are saved incorrect (library editor)
4.3.1175 (21/10/2019)
Added DyLOS support for multi-part fixtures
4.3.1174 (17/10/2019)
4.3.1171 (4/10/2019)
Added DyLOS pixel engine (currently limited to 5 zones per show, 1 layer per zone, all content scaled to 256x256 pixels internally)
Improved user interface focus and navigation (arrow keys activated) management
Moved to 64 bit
