I’m reposting this here as I believe it’s a bug in some of the newer releases and I can confirm this issue on build 4.8.1240 as well as the new beta 4.9.1248, I have reverted back to build 4.8.1237 as they work as expected in that build. I have not tested build 1238 or 1239.
the problem is that the 10 buttons on the right side of the NXP (the playback/function buttons) become non-responsive if I set that wing ID to anything other than 0, at the same time neither of the blue leds that indicate whether those buttons are in play or function mode will illuminate.
