A new beta is available with some bug fixes and improvements.
Installer:https://files.obsidiancontrol.com/s/kFQsqxXWtA6qWYH
Generator Guide: https://files.obsidiancontrol.com/s/n99kiYwTB2TWFyP 31
New content package to add palettes: https://files.obsidiancontrol.com/s/C8mSn6owEYLAgRJ
Release Notes for Onyx
(C) 2018-2020 - Obsidian Control Systems
4.5.1203 (19/11/2020)
DyLOS values are now shown in live output (origin indication pending)
Improved 2D plan performance and responsiveness for large fixture sets
Added LTC audio input level control for Obsidian timecode boards (not verified against hardware)
Fixed optimizing show files (removing fixtures that had been marked for deletion)
Fixed placing multi-part fixtures on 2D plan
Minor fixes and improvements
4.5.1202 (29/10/2020)
Fixed highlight
Fixed DyLOS folder selection
4.5.1201 (21/10/2020)
Added 3-preset pixel mapping mode and opacity mapping modes
Fixed application window lags while moving on some systems
Fixed 2D plan orientation pulled in from Capture 3D positions
4.5.1200 (21/09/2020)
Added DyLOS generators:
- Patterns: Plasma, Voronoi
- Nature: Fire, Steam
Updated NX Remote app
Fixed M-Play bank issues
4.5.1199 (30/07/2020)
4.5.1198 (24/07/2020)
4.5.1197 (10/07/2020)
Improved P/T Combo handling
Fixed joining shows
4.5.1195 (08/06/2020)
Added MSD (CITP) integration
4.5.1194 (02/06/2020)
