Checking Windows Event Viewer there are two events on Onyx start:
Warning - MsiInstaller - EventID 1001
Detection of product ‘{26E9BB4B-3842-4A08-9D10-1F5F618AD5EC}’, feature ‘Maxxyz’ failed during request for component ‘{50686E10-13C9-4487-965B-7921C38EF08A}’
Information - OnyxMemoryManager - Event ID 0
The description for Event ID 0 from source OnyxMemoryManager cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
*The following information was included with the event: *
If this happens at the second launch, it means the previous one didn’t close completely. We’re still looking at such issues, but meanwhile you could use the HaltOnyx script (in Program Files\Obsidian Control Systems\Onyx) or reboot between launches.
OK have just tried the suggested uninstall/install1057/uninstall/installBETA sequence - doing a reboot between each stage. No luck I’m afraid, still hanging on “Starting LIVE output”. DAX Error box is coming up on first Onyx start.
Same errors coming up in event viewer too.
Original Onyx version I was attempting to upgrade from was 4.2.1045.0
DAX errors will not appear if the install is correct, so there is some old files left after an uninstall. Please check your program files folder and registry if you are familiar with such tasks?
As indicated on the other thread, I suspect it’s an even older installation that left things behind. Could I have a TeamViewer (or something familiar) session to your (or anyone else’s facing the same problem) system? Hopefully I can determine a specific version so I could put out a generic note.
So, I identified a previous 3.71.* or 3.72.* M-PC install may cause leftovers that prohibit the latest beta from working. Here’s an adjusted procedure for trying to make it work:
