Please assign the new Dylos weight controls to the Intensity parameter group if you get a popup after loading a show. Or reload all factory defaults to put them into the right place.
Weight Control: Decides if the fixture uses Dylos output or “regular” parameter values. Its an HTP control, also allowing better blend in an out of Dylos and “other” programming.
4.5.1198 (24/07/2020)
4.5.1197 (10/07/2020)
Improved P/T Combo handling
Fixed joining shows
4.5.1195 (08/06/2020)
Added MSD (CITP) integration
4.5.1194 (02/06/2020)
That same “bar” disappears for me when I enter and leave the patch. It will come back for me if I minimize, maximize, adjust, or move the window, as well as when I click that bar’s new fader popup. My resolution is 2160x1440 at 125% scaling.
In order to have a Pixelmapping using a Beye group, now we have to do more steps than before
After doing the usual, we move the Mapping Weight parameters, but now it turns out that also, the value of Shutter Open, needs to be marked in the programmer, because it does not work on output (capture)
That is to say, they have added 3 new steps, in order to have output with Dylos, something that is much more confusing, and in step that I think they complicate something that was easier
I recorded a cuelist with dylos, and not work, always, i need active the instensity and shutter in the programmer, to see dylos output
Direct Weight seems to cause some issues with my gobo spin ! it looks like it’s interfering with it stoping or changing it in a “ccw rot” strange stuff ,this is happenning in this way!
I have stored a cue with position colour and gobo into the center position, gobos are spinning slowly,when i use the new features i prepare dylos with video then use the first inensity weight to morph dylos in and that’s ok! but if I try the “direct intensity” and move it slowly it first shuts off the entire cue ,so no fixtures visible like an inserted shutter,then if I go up slowly i have very weird behaviour maybe i didn’t get how this should work ! If you could explain me both realy good I will try to understand how to!
I do believe that virtual displays no longer work. Open a show file and only 1 window opened. Tried to create a show from scratch to test, still only single window
IMPORT PATCH FROM CAPTURE
Importing 76 universes of fixtures from Capture with the import feature in Onyx can we have same pop up as when we save a show with media telling us visually where we currently are?
THERE IS AN ISSUE CAUSE i HAVE TRIED THIS BEFORE AND IT WORKED BUT IN THIS LATEST RELEASE IT DOESN’T
Create a cue with an intesity fx running with 50 % speed store and clear.
select fixtures and create a cue with only the speed at 0% then clear.
set it as a/b fader release in 1.5 fade out first all will be working fine.
release it then close all.
So at the end what you got is a cuelist of 2 cues 1 with the fx ,and the second is the speed so when terring down the fader you would have a slow down of the speed.So two usefull things with one fader .
Now store your show, close Onyx and then re open It load the show, try the cues with the a/b fader,and you will see it doesn’t work! what am I missing i am sure that in previous version I have used it with no issue!
Please let me know so I can do it in the right way!
Thanx!
