This beta includes some major new features for DYLOS and CITP support
DYLOS:
Mapping of video to via presets (single preset modulation or between 2 presets)
Dylos can control ANY parameter like Movement, Zoom, Iris etc. as long as they are in the preset
New generators like plasma, fire, smoke, circle, squares etc to create dynamic content in real time
New palette concept for multi color or gradient control of generators
Improved weight mode calculation with selection (1 is as current)
New mapping styles for RGB/CMY and dynamic use of Intensity
CITP:
automatic generation of a 2D Plan when importing fixtures based on top and front view
Please test the following issues that we are investigating:
Window lag (seems driver or cpu dependent) : drag ONYX over the screen, does the window follow as expected or does it have a major delay after you stop moving the mouse?
2 Preset: On some graphics cards the 2 Preset Mapping is not functional. Please report back if the 2 Preset works or not on your systems and provide some details of your system spec (CPU/GPU)
We require this feedback to finalize this version and appreciate everyone helping us with these tests.
Generator Guide: https://files.obsidiancontrol.com/s/n99kiYwTB2TWFyP
New content package to add palettes: https://files.obsidiancontrol.com/s/C8mSn6owEYLAgRJ
Release Notes for Onyx
(C) 2018-2020 - Obsidian Control Systems
4.5.1200 (21/09/2020)
Added DyLOS generators:
- Patterns: Plasma, Voronoi
- Nature: Fire, Steam
Updated NX Remote app
Fixed M-Play bank issues
4.5.1199 (30/07/2020)
4.5.1198 (24/07/2020)
4.5.1197 (10/07/2020)
Improved P/T Combo handling
Fixed joining shows
4.5.1195 (08/06/2020)
Added MSD (CITP) integration
4.5.1194 (02/06/2020)
