This is the first beta that includes the new library system powered by AtlaBase of almost 50.000 Fixture Profiles.
Please read this blog post about this change: https://obsidiancontrol.com/blog/post/the-new-onyx-library-powered-by-atlabase/
It also contains important improvements to DyLOS , additional DyLOS Effects controls and features, and concludes the introduction of Preset based DyLOS effects on any parameter.
Existing shows will load, and patched fixture types can be exchanged for new library types in the patch. This is not mandatory, but any feedback on this process is very welcome.
Any new patching of fixtures will use the new library format. You can download the latest library which is automatically replaced every day: https://support.obsidiancontrol.com/Content/Support/temp/New_Fixture_Library.htm
Please examine the fixtures carefully and report all issues, wrong defaults or a missing gobo image.
Library additions and fixes are NOT guaranteed during the beta process, and until the release is available the time to receive libraries may be longer than usual.
It may require additional coding and improvements on ONYX to make it work. However your library reports are essential to ensure the new system works well. We really appreciate the beta testers taking the time to check all fixtures they use in detail.
The library switch is a major change and there are bound to be some hiccups. Please keep all your current showfiles and do not save over them, so you can always roll back if needed.
Also test and review this version carefully and recheck your programming before using it on any shows. Report back any changes or issues so we can finalize this for a release.
DOWNLOAD 4.5.1204 https://files.obsidiancontrol.com/s/gg2LSDGQ3QnoNiR
Content File with new Color Pallets https://files.obsidiancontrol.com/s/C8mSn6owEYLAgRJ
4.5.1204 (24/12/2020)
This version introduces a new fixture libary format, provided by the new libary partner AtlaBase. This library includes almost 50.000 fixture profiles
Please review all required fixtures carefully and request missing fixtures and report errors, wrong defaults etc on the new fixture request page for Version 4.6
Existing fixtures will remain in the showfile but can be replaced using the “Exchange” function in the patch menu.
User fixtures and the Library Editor are not affected and remain available.
This library is only availble for Version 4.5 and higher. Previous 4.2 console versions will receive an update to enable support for the new library.
Until release both library systems remain actively supported.
New fixture library format
- Daily update of new library package on Obsidiancontrol.com
- Single file library package (no longer an installation)
- Faster software install, bootup, library updates
- Update library from System Menu /Tools/Maintenance
- Library data is perfectly synchronized with Capture fixtures, allowing for easy import of the patch over CITP
- Revised Parameter Defaults and Snap Rules(e.g. additive LED fixtures now have all colors defaulted to 100%)
- -> this can affect existing programming and cues and presets must be adjusted if needed!
- Enhanced real world values (e.g. Zoom Ranges, Shutter Speeds, Framing Blade Angles)
- Improved Parameter names and feature descriptions
- Enhanced gobo and effects bitmaps, color buttons for CTC and Color Wheel Selections
Completed 3-preset pixel mapping mode and opacity mapping modes - BREAKING changes for existing shows using this feature
4.5.1203 (19/11/2020)
DyLOS values are now shown in live output (origin indication pending)
Improved 2D plan performance and responsiveness for large fixture sets
Fixed optimizing show files (removing fixtures that had been marked for deletion)
Fixed placing multi-part fixtures on 2D plan
Minor fixes and improvements
4.5.1202 (29/10/2020)
Fixed highlight
Fixed DyLOS folder selection
4.5.1201 (21/10/2020)
Added 3-preset pixel mapping mode and opacity mapping modes
Fixed application window lags while moving on some systems
Fixed 2D plan orientation pulled in from Capture 3D positions
4.5.1200 (21/09/2020)
Added DyLOS generators:
- Patterns: Plasma, Voronoi
- Nature: Fire, Steam
Updated NX Remote app
Fixed M-Play bank issues
4.5.1199 (30/07/2020)
4.5.1198 (24/07/2020)
4.5.1197 (10/07/2020)
Improved P/T Combo handling
Fixed joining shows
4.5.1195 (08/06/2020)
Added MSD (CITP) integration
4.5.1194 (02/06/2020)
