Please recheck all libraries well in advance before using any 4.5 version on a show. The changes are substantial and some libraries will have bugs or cause delays or hangups in ONYX.
During the beta phase the user can not assume that the library is available or fully functional, it needs to be verified. We appreciate everyone’s help to find bugs andreport any fixture profiles issues.Report all library issues to
https://support.obsidiancontrol.com/Content/Support/temp/New_Fixture_Library.htm
This version fixes some reported bugs Also the Generic Fixture Libraries are re-added and sorted into multiple categories. Some minor cleanup items remain for the Generics.
https://files.obsidiancontrol.com/s/tRE4WPzibHzyc2j
DOWNLOAD Content File with new Color Pallets
https://files.obsidiancontrol.com/s/C8mSn6owEYLAgRJ
Release Notes for Onyx
(C) 2018-2021 - Obsidian Control Systems
4.5.1206 (03/02/2021)
Added current universe fixture filter in patch
Improved Art-Net and sACN input options
Improved orientation of fixtures on Capture import
Fixed first fixture in patch not having its opacity mapped correctly
Fixed fixture selection focus for multi-part fixtures without a main part
Fixed LOAD+LOAD using keyboard shortcut
Fixed copying between types of Fixture Groups
Fixed playback fader (1-10) LEDs on M-Touch, NX Touch while not in “Play” mode
Fixes for fixture type search
Additional fixes for applying additive color FX macros
4.5.1205 (18/01/2021)
Added DyLOS mirror effect
Added DyLOS tunnel effect
Added framing and iris to DyLOS zone slot
Added DyLOS frame blending
Continous/loop improvements on DyLOS
Installer improvements to avoid SQL-related errors in uninstall of 4.5.1205 builds and later
Fixed fixture rotation on 2D plan being ignored for pixel mapping
Fixed pixel mapping to ignore master parameters specifically
Fixed importing AtlaBase parameter group assignment into new show
Fixed applying additive color FX macros
Fixed error popup in selected cuelist view when using keyboard shortcut to delete cues
Fixed saving types in library editor
4.5.1204 (24/12/2020)
This version introduces a new fixture libary format, provided by the new libary partner AtlaBase. This library includes almost 50.000 fixture profiles
Please review all required fixtures carefully and request missing fixtures and report errors, wrong defaults etc on the new fixture request page for Version 4.6
Existing fixtures will remain in the showfile but can be replaced using the “Exchange” function in the patch menu.
User fixtures and the Library Editor are not affected and remain available.
This library is only availble for Version 4.5 and higher. Previous 4.2 console versions will receive an update to enable support for the new library.
Until release both library systems remain actively supported.
New fixture library format
Daily update of new library package on Obsidiancontrol.com
Single file library package (no longer an installation)
Faster software install, bootup, library udpates
Update libary from System Menu /Tools/Maintenance
Library data is perfectly syncronized with Capture fixtures, allowing for easy import of the patch over CITP
Revised Parameter Defaults and Snap Rules(e.g.additive LED fixtures now have all colors defaulted to 100%)
-> this can affect existing programming and cues and presets must be adjusted if needed.
Enhanced real world values (e.g. Zoom Ranges, Shutter Speeds, Framing Blade Angles)
Improved Parameter names and feature descriptions
Enhanced gobo and effects bitmaps, color buttons for CTC and Color Wheel Selections
Completed 3-preset pixel mapping mode and opacity mapping modes - BREAKING changes for existing shows using this feature
4.5.1203 (19/11/2020)
DyLOS values are now shown in live output (origin indication pending)
Improved 2D plan performance and responsiveness for large fixture sets
Fixed optimizing show files (removing fixtures that had been marked for deletion)
Fixed placing multi-part fixtures on 2D plan
Minor fixes and improvements
4.5.1202 (29/10/2020)
Fixed highlight
Fixed DyLOS folder selection
4.5.1201 (21/10/2020)
Added 3-preset pixel mapping mode and opacity mapping modes
Fixed application window lags while moving on some systems
Fixed 2D plan orientation pulled in from Capture 3D positions
4.5.1200 (21/09/2020)
Added DyLOS generators:
- Patterns: Plasma, Voronoi
- Nature: Fire, Steam
Updated NX Remote app
Fixed M-Play bank issues
4.5.1199 (30/07/2020)
4.5.1198 (24/07/2020)
4.5.1197 (10/07/2020)
Improved P/T Combo handling
Fixed joining shows
4.5.1195 (08/06/2020)
Added MSD (CITP) integration
4.5.1194 (02/06/2020)
