ONYX Beta 1211
Resolved the bugs reported in 1208.
Some reported slowness on first show load is due to a conversion needed for Dylos parameters. Save the showfile with 1211 and this should be solved.
		Release Notes for Onyx
	(C) 2018-2021 - Obsidian Control Systems
4.5.1211 (19/03/2021)
Fixed DyLOS channel assignments
4.5.1210 (18/03/2021)
Fixed DyLOS enabling and update issues
DyLOS thumb overlay fixes and improvements
4.5.1209 (16/03/2021)
Added configurable DyLOS thumb overlays, optionally showing curves for matrix generators and mapping gamma curves
Fixed fixture type library browser issues (like popping up again after adding fixtures)
hello,
generators from dylos content are not longer scrolling in 1211!!
thx.
r.h.
hello, is there a way to avoid the dark green on cmy fixtures, when a dylos zone slot should be real black.
we tryed with contrast, brightness and different videos in different codecs bevor import.
no way to get real black on the fixtures from the dylos webinar capture file.
is there a prefered way to do this?
thx.
r.h.
…and the directx problem seems to be back.
we install the components you share in the forum.
but:
thx.
r.h.
The “Dynamic Intensity” in the mapper is exactly made for this.
You need to reinstall ONYX after redoing the Direct X.
hello, dynamic intensity do not work for us.
if we switch it on, all fixtures going to full and dylos lose control.
to get dylos control over the fixtures back again, we have to disable dynamic control.
what are we doing wrong?
we uploaded a video to this link:
and here:
thx.
r.h.
…not scrolling generators, gradients.
generator_not_scrolling.mkv (8.9 MB)
do we something wrong?
thx.
r.h.
We’ve been able to reproduce, tnx for the report, will be fixed in the next build
We can’t reproduce unfortunately, did you happen to set opacity values as well? Could you otherwise upload your show file so we can have a look?
Unable to get Load Load to work correctly in Dylos webinar showfile…
Is this somehow being affected by Dylos??? Appreciate any insight.
Thanks
sorry which one of the issues shold i descripe with a show file?
a, the not scrolling generator,
or,
b, the dynamic intensity thing
thx.
r.h.
The scrolling generator is being corrected.[quote=“deflost, post:13, topic:6636, full:true”]
or,
thx.
r.h.
[/quote]
…we uploaded a showfile with this name:
dynamicintensityfail_2021-03-22_1812_Build_4_5_1211_0.OnyxShow
it is fresh, patch is imported from capture .exe out of the dylos webinar files,
without any problem.
works as far as reported.
but, no dynamic intensity control.
it makes all fixtures to show full, if we activat it in mapping of zone.
like in the video above.
thx.
r.h.
I have this issue. What is the process for “redoing the Direct X”?
Edit: Maybe I spoke to soon. I rebooted and it’s fine now. (This occurred right after I “Exchanged” some fixtures to the new library versions in Patch.)
A lot of 2D combined symbols are wrong For example, in the elation library, the Chorus Line, Protron eclypse are in a Big Circle, And Rayzor 760 is so big
In beta 1207 I cloned a fixture in an active cue and it caused the RGB lights in that cue to go to white. I also had one of those in the programmer. I initialized the cue again and it, fortunately, went back to the look I had before executing the clone procedure.
From release to 12 11 , I had to install 1207 before being able to install 1211.
Hi have installed the last beta in M2GO-HD
Issues:
All USB connections are discennected
Small display disconnected- on black
Only work Touch-Screen, keyboard on back, USB-DMX interface connected on back
Seem like all externals USB are disconnected
thank you for your job
You may have to reinstall the OS. What was on it before the update?
