Hi Everyone,
This is the third release candidate of this beta cycle.
This version replaces [Onyx Beta 4.31.1296]
This version was replaced by the Release 4.32.1301
Important Notes:
- Post all beta-related feedback, including bug reports and observations, in this thread.
- For feature requests and unrelated issues, use the appropriate thread or email support@obsidiancontrol.com.
We recommend testing in a controlled environment with enough time to roll back to a non-beta version if needed.
Release Notes:
4.31.1300 (23/05/2025)
- ONYX-1137 Added NDI Discovery Service support
NOTE: When using 2 network connections (for example, one NDI and one Art-Net) to connect the same systems, it is best to use the NDI Discovery Service and bind it to the appropriate NIC (and configure its IP address in ONYX) to make sure the NDI stream is sent on the intended connection
4.31.1299 (23/05/2025)
- ONYX-778 Fixed RGB flags not being rendered in 2D plan
- ONYX-846 Visual fixes in 2D plan
- ONYX-1042 Fixed rendering text to multi-target displays (like playback name displays on NX4/M6), NX W fixes
- ONYX-1204 Fixed CMY emitters not being rendered in 2D plan
4.31.1298 (19/05/2025)
- ONYX-846 Fixed 2D plan not showing
4.31.1297 (16/05/2025)
- ONYX-1042 Added NX W control surface support
- ONYX-1187 Revised license schemes to “ONYX Key”
- ONYX-1201 Fixed FADE and DELAY (and WEIGHT) keyboard shortcuts not working
- ONYX-1198 Support ring segments for pixel mapping
- ONYX-1196 Fixed Ableton Link changing session tempo when closing ONYX
- ONYX-1194 Fixed 2D plan Groups tab when adding objects not showing colors
ONYX-1192 Fixed preset names not showing correctly in programmer and cuelist values - ONYX-1186 Fixed undetected local NDI sources
- ONYX-1178 Fixed order issues causing emitters not being visualized on 2D plan
- ONYX-1148 Fixed inability to select multiple groups (using drag) while 2D plan is in live mode
- ONYX-1108 Fixed X-Net connection dropping
- ONYX-846 Several 2D plan fixes and improvements, including extended zoom out range and page map panel
- ONYX-1155, ONYX-1138, ONYX-1092, ONYX-1075 Visual fixes and improvements
