We have reached the point in the 4.8 Development cycle that we are ready to start the beta testing process.
This version can be installed currently as an update to 4.6. However, it will require a full OS install on consoles when released. Included below are the installer and full OS.
Please review the beta and specifically check the following options
Wing IDs
Quickview Button
Install and Uninstall on PC Systems.
If anyone has a PC that doesn’t install ONYX due to an SQL error we want to know if this version works for you and the error no longer appears.
Please provide any feedback (bugs, issues, comments) for this version by replying to this post to keep everything in one place.
Happy Testing!
Release Notes:
4.7.1234 (7/07/2022)
Dropped SQL server instance sharing: each user will run his own instance against shared data files; this should eliminate login errors during installation
4.7.1233 (6/07/2022)
Fixed XNET connection reliability issue
Fixed rendering (color mixing) channels that are not linear across the entire DMX value range
4.7.1232 (24/06/2022)
Added support for NX1, NX-K, NX-P
Added support for wing ID on virtual panels
Improved and unified device management (configuring wing ID, DMX universes)
Playback fader flip (1-10 ↔ 11-20) is now applied per wing ID (instead of global)
Multi-function button mode (Play, F-Keys, Base, FX) is now applied per wing ID (instead of global)
Fixed new fixture types in library update can only only be added after restarting software
Fixed wrong fixture types matching on CITP import from Capture
Fixed programming issues when using encoder to reach zero while operation mode is absolute (jumping to full)
No, different branch, didn’t risk to keep NX1/NX-P/NX-K waiting in the factory when ready before these new features would be good enough for release (as it is turning out). Coming very soon, though!
Issue with Quick view when scaling the window
small on PC sys .
Once scalled the window small click on the cross in the middle,It Will resize and scale parameter window but It eliminates the entire Quick view section,when you enlarge It again ,there is no way to have that view back.
Even if you reload the view,only action that works ,is that you need to re start Windows and Onyx, otherwise if you close Onyx ,and atemp to restart It Will not open.
I believe there is a bug with the 2D Plan view when selecting groups consisting of either parts only or masters only. I have noticed that it can only be selected when the “Master Only or the Master and Parts” filter selection is selected. In 1226 it was possible you could select a 2D Plan group using “Parts Only” also. There also seems to be an issue with storing the 2D Plan view with the parts only selection method. It appears that you have to switch to master and then back to parts to get it fully to work. Still trying to see how best to capture this. Hopefully this video comes across. Let me know if not.
