ONYX Beta 4.9.1249
Please update to the latest beta and review the improvements outlined below
https://files.obsidiancontrol.com/s/beta4_9_1249
4.9.1249 (23/02/2023)
Notice: loading show files created with the previous beta (4.9.1248) will require to re-select audio input channels and/or turn NDI devices off and back on if they are used by input processors
Added beat detection sync into media playhead and chase playback (beat triggers, next to global)
Fixes and improvements to input processor workflow
Fixes and improvements to audio input processors
Allow P/T values in highlight/lowlight presets
Default values view will only show changed values
Aspect ratio improvments (covering masks)
Aspect ratio fixes for still images, rotation and scaling
Fixed live thumbnails not always rendered correctly
Fixed “non-selected fixtures” option on CLEAR being ignored when no fixtures are selected
Fixed playback fader buttons 11-20 and F-keys not working on NX-P when its Wing ID is not zero
4.9.1248 (13/01/2023)
Added aspect ratio control
Added multi-select for audio input channels
Added output override feedback to live output
Improved DyLOS input processor management
Improved DYLOS input processors’ accuracy
Improved parameter-level parking
Improved default value editing
4.9.1246 (19/08/2022)
Added input processors to DyLOS for converting external inputs into modulators (triggers pending)
  • added video and palette input processor (NDI; aspect ratio channel/parameter not bound yet)
  • added audio input, filter and analyzer processors (NDI, ASIO; multi-select audio channels pending)
Added output overrides as special presets that are edited in dedicated programmer context (“copy from” to start from regular presets pending)
  • added parameter-level parking (value feedback in parameter panel still being tuned)
  • added channel-level offsets
  • improved default value editing (clear doesn’t work yet from popup for input processors, feedback for default editing still being tuned)
  • improved highlight/lowlight editing
Same issue I was having on 1248. The NDI source can be seen in the preview. But will not show up when mapped to a source.
Update to this. I tried another input from an NDI scan converter and it worked without any issues. However, the Resloume NDI output still shows in the preview but not in DYLOS. Picture attached.
What version of Resolume are you running?
7.0.5
Sofware soft lock (freeze) when a beat detector select as input beat divider
every time i relunch the software and go see my dylos input. the app freezes
(unable to undo mistake unless you load back old file)
Great. Now the audio input actually works for me. Would someone mind sharing a tutorial or examples for how the audio input can be used?
I basically got a white pulse / flash and can color that flash but it’s all the same color. The audio beat detector doesn’t appear to affect the Dylos parameters, such as speed, gobo spin, etc. how do you assign the audio input to individual parameters?
For example, the External FFT setting in Resolume, as you may be aware, is an option next to each usable parameter. This approach seems quite different. I would rather be able to assign the audio input to any given parameter. Imagining that the devlopment phase of the audio is still in prototype.
How-to make a new default value? When setting a fixture to a default value, record it to … default … ?? But now? A new screen with all fixtures is popping up, but I cannot record my default values ? A known issue? Thanks for an answer :+1:
I found it myself. Another way than before. (no use of record anymore)
Open window “Default” > edit “on” > set the fixture parameters correct > edit “off”. Done.
(post deleted by author)
