Hi Everyone,
Please update to the latest beta and review the improvements outlined below.
As always, please keep all discussions and comments about this beta to THIS forum post.
Happy testing!
4.9.1251 (15/05/2023)
Added target assignment of reference processors to F-Keys
Added support for Ableton Link Quantum Phase Synchronization
Added support for changing the tempo in an Ableton Link session
Added support for reverse playback for synced media playback and generators
Extended Beat F-Key assignment to any beat-tap processor
Fixed importing fixtures using CITP on non-English systems
Fixed fixture range selection issues
4.9.1250 (18/04/2023)
Dropped 32 bit driver support
Updated to SQL Server 2022 for support continuity
Updated to latest CodeMeter, NDI and Visual C++ runtimes
Completed (audio, beat) input processor workflow
Added Ableton Link support (input processor)
Added MIDI Clock support (input processor)
Added beat-tap processor (replacing former global beat for chases)
Added reference processor (to decouple source input slot programming in presets and cues through indirection)
Added metronome visual feedback for beat rate
Added “Copy from” between highlight/lowlight presets
Improved audio beat detection accuracy
Fixed (Capture) visualizer focusing via CITP while offsets have been configured
4.9.1249 (23/02/2023)
Notice: loading show files created with the previous beta (4.9.1248) will require to re-select audio input channels and/or turn NDI devices off and back on if they are used by input processors
Added beat detection sync into media playhead and chase playback (beat triggers, next to global)
Fixes and improvements to input processor workflow
Fixes and improvements to audio input processors
Allow P/T values in highlight/lowlight presets
Default values view will only show changed values
Aspect ratio improvments (covering masks)
Aspect ratio fixes for still images, rotation and scaling
Fixed live thumbnails not always rendered correctly
Fixed “non-selected fixtures” option on CLEAR being ignored when no fixtures are selected
Fixed playback fader buttons 11-20 and F-keys not working on NX-P when its Wing ID is not zero
4.9.1248 (13/01/2023)
Added aspect ratio control
Added multi-select for audio input channels
Added output override feedback to live output
Improved DyLOS input processor management
Improved DYLOS input processors’ accuracy
Improved parameter-level parking
Improved default value editing
4.9.1246 (19/08/2022)
Added input processors to DyLOS for converting external inputs into modulators (triggers pending)
- added video and palette input processor (NDI; aspect ratio channel/parameter not bound yet)
- added audio input, filter and analyzer processors (NDI, ASIO; multi-select audio channels pending)
Added output overrides as special presets that are edited in dedicated programmer context (“copy from” to start from regular presets pending)
- added parameter-level parking (value feedback in parameter panel still being tuned)
- added channel-level offsets
- improved default value editing (clear doesn’t work yet from popup for input processors, feedback for default editing still being tuned)
- improved highlight/lowlight editing
