Awesome guys!
Thanks for your support Gert! Much appreciated !
Problem of installation almost resolved by itself, no real known issue, maybe a missing reboot in between?
Then, if you have show file loading time very long, check that you don’t have an old big Onyx fixture library (coming from old time before Atlabase one as example), it can make the show migration time very important. (default location: C:\Users\Public\Documents\Obsidian\Onyx\Fixture Library)
Thanks for the report, will be fixed in next build
Hi Obsidian Team,
Another bug in .1251 (haven’t checked 1252 yet to see if this has carried-over).
The FX Timing > Wave function of the FX Generator appears to be partially-broken. Previously, when more than one fixture was selected, the top of the “Wave” encoder belt would display a shortcut to wave-by the total number of fixtures selected.
Beginning in .1251, the value displayed is erroneous. i.e; if 8 fixtures are selected, the FX Generator will think 31 fixtures are selected. This issue has been consistently reproducible at my end. The toolbar at the top of the screen seems to display an incorrect qty of fixtures selected as well.
I’ve recorded an example of this, viewable via the following link. In this video I’m selecting a group that has 8 fixtures in it (triple checked!), but the toolbar & FX generator are displaying “20”.
Here is another bug I have been experiencing in 4.8.1244 and before (still happen on this version)
When you add a tile effect from the Dylos zone parameter and select the tile X and Y everything works ok but the mirror Tiles it doesnt work… You have to open the parameters editor to change it
Fyi: I did some testing yesterday. It worked with 4.5 and broke with the release of 4.6.
I disabled long press for right click, but it didn’t had any effect within onyx unfortunatly.
The issue has been fixed on 1253… Check the patch notes
You have to directly select the mirror tiles and change the tile X and Y at the bottom
If you selected normal tiles and selected the appropriate tile X and Y and go to mirror tiles it works
