I can’t install the last version of Onyx because of the error 27502
I tried many ways to fix it, on different topics of the forum, without result…
- Manually via cmd.exe
- FixLoginError.vbs as admin
- Onyx cleaner V1
Thanks in advance,
Vince
Thanks in advance,
Vince
If Onyx is currently installed, and you get the error when trying to uninstall, run the following on a command prompt with administrative priviliges:
sqllocaldb create ObdisianControl
sqllocaldb share ObsidianControl ObsidianOnyx
and try uninstalling again; if Onyx is not currently installed, and you get the error when trying to install, run the following on a command prompt with administrative privileges:
sqllocaldb unshare .\ObsidianOnyx
and try installing again
Hi!
Thanks a lot Gert, it was for install and it works now.
Vince
