The next Beta is avalable. This adds a 3 preset mode (Black/White and adjustable Grey), improves blending from regualar to Dylos values and further improves the capture 2D Plan import.
Release Notes for Onyx
(C) 2018-2020 - Obsidian Control Systems
4.5.1202 (29/10/2020)
Fixed highlight
Fixed DyLOS folder selection
Minor fixes and improvements
4.5.1201 (21/10/2020)
Added 3-preset pixel mapping mode and opacity mapping modes
Fixed application window lags while moving on some systems
Fixed 2D plan orientation pulled in from Capture 3D positions
4.5.1200 (21/09/2020)
Added DyLOS generators:
- Patterns: Plasma, Voronoi
- Nature: Fire, Steam
Updated NX Remote app
Fixed M-Play bank issues
4.5.1199 (30/07/2020)
4.5.1198 (24/07/2020)
4.5.1197 (10/07/2020)
Improved P/T Combo handling
Fixed joining shows
4.5.1195 (08/06/2020)
Added MSD (CITP) integration
4.5.1194 (02/06/2020)
