Onyx Beta 4.31.1292
Replaced by Onyx Beta 4.31.1294 (RC1)
Hi Everyone,
We’re kicking off a new Onyx Beta cycle, packed with new features, improvements, and fixes!
Important Notes:
  • Post all beta-related feedback, including bug reports and observations, in this thread.
  • For feature requests and unrelated issues, use the appropriate thread or email support@obsidiancontrol.com.
  • :warning: This beta has not been show-tested. We recommend testing in a controlled environment with enough time to roll back to a non beta version if needed.
:page_facing_up: Preview Documentation: Onyx Beta Preview Manual
:inbox_tray: Download: Replaced by Onyx Beta 4.31.1294 (RC1)
Release Notes
New Features
  • ONYX-939 Added LTC Audio timecode input processor
  • ONYX-1109 Added AnyDesk to diagnostic tools for remote support
  • Added “Release” value in cues to release a channel from tracking through subsequent cues
  • Added new “Skip” cue option for genuine cue-only behavior (values previous cue tracked through in next cue rather than hard coded value duplication in next cue)
  • Added dual fixture group mapping mask with logical combination options
  • Added gobo pixel mapping mode
  • Added weight sub channels to cross fade direct ↔ pixel-mapped output per parameter
  • Added fade/delay/weight editing modes behind double click on LINK button
  • Added fixture group mapping mask
  • Added palette support to effect slots
Updates / Improvements
  • ONYX-1025 Improved parameter encoder behavior and range locking
  • ONYX-74 Improved show backup naming (BeforeCreate/Load/Optimize/Upgrade now became a prefix for the file name that includes show name, time and build)
  • ONYX-1025 Improved FADE/DELAY/WEIGHT editing mode toggling
  • ONYX-1112 Allow install of latest Focusrite ASIO driver installers (including 4th generation); 3rd party (ASIO) packages can now also be uninstalled
  • Improved gobo pixel mapping mode
  • Improved consistency of using channel and parameter group buttons with CLEAR/DEFAULT/LOAD/SET SELECTION on command line
Fixes
  • ONYX-1088 Fixed Patch help
  • ONYX-1094 Fixed [GROUP] [ENTER] not pulling any fixture, that is not at zero intensity, into programmer; [GROUP] [FULL] will now work as [GROUP] [@] [FULL]
  • ONYX-1115 Fixed DyLOS color palette selection and preview issues
  • ONYX-1037 Visual and recording fixes for parameter releases in cues
  • ONYX-1112 Fixed uninstall of Focusrite packages
  • ONYX-1065 Fixed intensity output in cuelist ID 10,000 and up
  • ONYX-1116 Fixed software grand master (in title bar)
  • ONYX-1124 Fixed “Division by zero” error when attempting to scroll using 2 touch points
  • Fixed WEIGHT not being applied to Pan/Tilt and “random” other values
  • Fixed CLEAR/DEFAULT/LOAD through right-click on parameter groups
  • Fixed FADE/DELAY OUT being applied when providing fanning value for IN
  • Fixed CLEAR SELECTION on programmer groups not considering BASE/FX/TIME filters
  • Fixed CLEAR FIXTURE
  • Fixes in weight tracking; Fixes in Weight clearing through filter
  • Fixed CLEAR on parameter group while in FADE/DELAY/WEIGHT editing mode
Miscellaneous
ONYX-1075, ONYX-1084, ONYX-1121, ONYX-1136, ONYX-1136, ONYX-1109, ONYX-1075, ONYX-1123, ONYX-1130, ONYX-1133
Hi to all!
Primary and secondary console via ART-NET ,Why when joining the show ,the secondary pc Opens secondary Sidebar ,and not the same as the primary? it’s a bit weird to my opinion,can we avoid this and make it exactly open as the “Primary” console.
Thanx to all! = )
Otherwise I need to do again another operation and switche sidebars!
Hi @Giancarlo
I’m not able to replicate this on my system. This is the process I am using:
  • NX2 & ONYX PC both running ONYX 4.32.1292
  • Customise show file and Sidebar items on NX2
  • On PC, Join NX2’s show file via X-Net
  • Upon loading the show file, ONYX PC loads the Sidebar items from the Primary NX2 as expected
Please make sure your Primary and Secondary system are both in the same Workspace.
Hi Edward try this on 2 pc’s maybe it does it!
But if I am using ONYX on a “Primary” PC,and I Joined the show on the 2 “System” meanwhile I am doing something else,What I expect is seeing exactly the same Page , Active Cues , Active fader, Selected Groups, etc. I don’t think I have to check if all is at the same place,as in the Primary pc. To my opinion this should be something that happens automaticly ,to me it’s obvious ,or you think no?
Please send me the show file that is running on your primary system, and provide step-by-step instructions on how you are joining the show file on your secondary system.
Hi Edward, It’s the file you already have,Just pushed" Join" at the begining of Onyx in Load Options,on 2 PC .
Obviously I have previously verified all Artnet connections,“Used the Ping in CMD” no Firewall activated etc…
It would be a great feature to have a fanning option in the new fade / delay option menu
Already asked for things like that something like 1thru 5 and other stuff already “Premade” as in the normal timing. = )
Hi @gogocharter
This feature suggestion is logged on our system as ONYX-1153.
hello, the clear funktion like:
clear fixture 3 enter,
for example, does not work in this beta!
we can also not:
press clear, then select a fixture, to clear its value from the programmer
is this only our problem with the new beta?
thx.
if we press clear, and select fixture x, it writes down to command line:
clear fixture x
in the versions before, it executes a value clear for that fixture without press enter. is this a change in the function or a bug?
thx
ok, gerd confirmes that this is a bug! dear all, please post a message here if you also think that a bug like this can not wait to be fixed till the next step of betas. there should be a fast fix, because we cannot test further if such a basic workflow funktion is broken.
what do you think?
thx.
Hi @deflost
Thank you very much for reporting this issue. This is logged on our system as ONYX-1156, assigned as high priority.
new beta:
hello, should the new double click function for the popup for fade/ delay/ weight option, also work with nxk? in our case it does not! is this normal?
thx.
it seems like the link buttom on the nxk in general not work anymore. thx.
I have an NX-K connected to ONYX PC 4.31.1292. Double tapping LINK, will open the new Link Mode popup as expected, allowing you to choose a mode…
Tapping LINK once, will enable/disable the chosen mode, and the LINK key will flash.
Double tapping FADE or DELAY, will correctly take you straight to this mode.
also fade and delay buttom on nxk is not working in the new beta! thx
we test this with 2 nx1 and 1 on pc setup. the nxk work ok in 4.30.1274, but not in 4.31.1292!
console tester says nxk keys are ok!
Thank you for confirming. I’m not sure why the LINK key isn’t working on your system. If you open the CV, and then double tap the onscreen LINK key in here, does the Link Mode popup appear as expected?
