Replaced with RC 4.9.1254: Onyx RC 4.9.1254
This build requires the 4.9.1252 OS on consoles. Update to this once 1252 is installed.
Happy Testing ![]()
Release Notes for Onyx
(C) 2018-2023 - Obsidian Control Systems
4.9.1253 (21/07/2023)
Notices:
- due to some fixtures and nodes not working at all when Art-Net and/or sACN sync is turned on, they are now turned off by default (also in existing shows that didn’t have the setting altered). Turn them on when you notice a lag between universes.
- click track beat detection appears broken and will be fixed for next build (because some of below fixes are rather critical, we decided not to wait for this specific fix)
Added options dropdown for library and beats editor views (library tabs can now be added as a view from the new “Library” Windows tab)
Fixed holding playback buttons on a touch screen to just hold instead of triggering the right click gesture (popping up the options window)
Fixed playback buttons focus issue causing their function assignments not being accessible
Fixed fixture selection grouping tools and last/next browsing
Fixed fixture park issues acroos XNET
Fixed PATCH command issues when show contains fixture(s) with numbers having more than 5 digits
Fixed assigning addresses to multiple multi-part fixtures without a main part at once
Fixed Cloning (PATCH) scope options inconsistency between batch entries list and selected entry data
Fixed mirror tiles configuration not working from zone parameters (only from parameters editor)
Fixed aspect ratio being calculated/applied for palettes
Fixed Telnet and UDP input not accepting square brackets around commands the way ONYX Manager did
Fixed excessive show load time when there’s an extensive User Library of fixture types
Various fixes to improve reliability, workflow/accessibility (like new Channels tab in zone parameters for quick access to intensity, opacity, speed master and scale mode; “Beats” editor view moved to new “Library” Windows tab) and status feedback (like park state, audio/beat input/link states, …), and to reduce latency
4.9.1252 (28/06/2023)
Notice: if you programmed values for the “BPM Target” channel of the Beat Provider, review your show file as its range has been extended
Allow for installing 3rd party ASIO drivers (to support low latency USB audio devices as published by Behringer, Focusrite, M-Audio, MOTU and RME), and added access to their mixer and configuration
Added transport running state (Ableton Link, MIDI clock, audio signal presence) tracking to (un)mute beat provider output
Added Telnet/UDP input: no longer needed to launch ONYX Manager for these protocols
Added audio monitoring
Added color appearance supprt to input processors
Improved and fixed Beat F-Key assignment
Improved access to reverse playback for synced media playback and generators
Improved Ableton Link tap responsiveness
Improved fixture selection ranges to no longer include DyLOS zone or input processor fixtures unless referred to explicitly
Fixed user fixture type profiles showing up in the browser, but not being added to the show after creating/editing
Fixed sACN universes not showing in DMX I/O selection dropdown
Fixed moving input processor to other slot
Various fixes to improve reliability and reduce latency
4.9.1251 (15/05/2023)
Added target assignment of reference processors to F-Keys
Added support for Ableton Link Quantum Phase Synchronization
Added support for changing the tempo in an Ableton Link session
Added support for reverse playback for synced media playback and generators
Extended Beat F-Key assignment to any beat-tap processor
Fixed importing fixtures using CITP on non-English systems
Fixed fixture range selection issues
4.9.1250 (18/04/2023)
Dropped 32 bit driver support
Updated to SQL Server 2022 for support continuity
Updated to latest CodeMeter, NDI and Visual C++ runtimes
Completed (audio, beat) input processor workflow
Added Ableton Link support (input processor)
Added MIDI Clock support (input processor)
Added beat-tap processor (replacing former global beat for chases)
Added reference processor (to decouple source input slot programming in presets and cues through indirection)
Added metronome visual feedback for beat rate
Added “Copy from” between highlight/lowlight presets
Improved audio beat detection accuracy
Fixed (Capture) visualizer focusing via CITP while offsets have been configured
4.9.1249 (23/02/2023)
Notice: loading show files created with the previous beta (4.9.1248) will require to re-select audio input channels and/or turn NDI devices off and back on if they are used by input processors
Added beat detection sync into media playhead and chase playback (beat triggers, next to global)
Fixes and improvements to input processor workflow
Fixes and improvements to audio input processors
Allow P/T values in highlight/lowlight presets
Default values view will only show changed values
Aspect ratio improvments (covering masks)
Aspect ratio fixes for still images, rotation and scaling
Fixed live thumbnails not always rendered correctly
Fixed “non-selected fixtures” option on CLEAR being ignored when no fixtures are selected
4.9.1248 (13/01/2023)
Added aspect ratio control
Added multi-select for audio input channels
Added output override feedback to live output
Improved DyLOS input processor management
Improved DYLOS input processors’ accuracy
Improved parameter-level parking
Improved default value editing
4.9.1246 (19/08/2022)
Added input processors to DyLOS for converting external inputs into modulators (triggers pending)
- added video and palette input processor (NDI; aspect ratio channel/parameter not bound yet)
- added audio input, filter and analyzer processors (NDI, ASIO; multi-select audio channels pending)
Added output overrides as special presets that are edited in dedicated programmer context
- added parameter-level parking (value feedback in parameter panel still being tuned)
- added channel-level offsets
- improved default value editing (clear doesn’t work yet from popup for input processors, feedback for default editing still being tuned)
- improved highlight/lowlight editing
