Telnet and UDP commands currently supported: CLRCLR, GQL, RQL, PQL, GTQ, RAO, RAQLDF, RAQLODF, RAQLO, RAQL, SQL
Improved consistency between various beat inputs and states
Improved grouping manipulation (changing the selection mask or its parameter)
Fixed Follow and Wait cues not working correctly on secondary systems
Fixed motorized fader crosstalk from virtual panel on different ID and bank
Fixed 2D Shapes (like Bouncing 2D Shapes) not working (showing white canvas) on some nVidia-based systems, as well as mask blending on some unspecified systems
1254
Hi to all!
Everytime I change the “STEP” , i think this happens also touching other parameters on the NORMAL FX engine, is that has the “COMBO OFF” that is the selected and needed one , changes to "ON " again.
Looks like Onyx reselects and activates the “COMBO” , so I need to reselect it and correct it to “OFF”.
Can you check it out please!
Scrolling causes visual glitches, while cuelists are playing back in cuelist directory.
Selection (Red tile) isn’t displayed either, when glitch is active.
8/14
Beat button on M-Touch has the Chase outlined when the button is pressed, giving the illusion that it works on the computer but it doesn’t do the same on the networked comptuer. Hitting the Play button in the chase still seems to work. Maybe I need to reassign it to global before the beat button works again. But there are certainly issues with the tap of the beat button and synchronization between two computers.
added 8/20
Couldn’t delete multi-part fixtures from the patch. Then when I imported a fixture the fixtures I was trying to delete disappeared and so were deleted.
It seems like this update introduced issues which worked fine in the previous beta. For example, when recording a cuelist to the main playback bar it doesn’t show the other cuelists steps as having been recorded until play the cuelist.
Not sure if this issue was there before but Onyx freezes when I try to add a generic multipart RBG Pixel , for example the 100 cell Pixel, to the 2D plan in Dylos stops Onyx from working.
Also a custom fixture I edited for a pixel strip doesn’t respond to the intensity levels of cuelists or inhibitives. I can only record the cuelist at a set level or use the live programmer to change the intensity level.
8/30
Was reminded that the change in licensing to a one universe of Artnet output to the Capture visualizer affects the demo show file, as only the first universe of output works. New users who want to demo Onyx won’t have a USB license key or other hardware unlocking the second universe of Artnet output.
9/3, noticed that when applying the Intensity FX it stops the strobe from working.
9/9 Can’t renumber cuelists (in the Cuelist Values window with Edit enabled).
It is on presets, sometime I lost all the visu of my preset (beam fx tab as example). I need to restart the NX1 to see them again (the scroll doesn’t do anything I see empty list of preset, but if I try to record other, I have the classical command to merge/replace etc… So it’s really seems to be a graphical issue somewhere.
It has also happen to me with virtual playback, but this only happened once in 1253, not 1254.
I had a weird effect with the MataBalls where they were glitching outin a constant way… I installed new graphics driver and restarted Onyx and it worked Fine
Maybe its because I started a new showfile and enabled Dylos the first time I lunched and created the project
Hi to all on the 1254 BETA VERSION
Everytime I ,copy or move or delete a processor,the windows clears all selected layers or whatever items where active!
why?
Cause in this way we always need to start again. Thanx to all!
So when in the HIGHLIGHT window, and I am using the “Last or Next” on keypad, everything is ok, when using the keyboard shortcuts like " CTRL +PG up or down " I can see some weird graphic glitches in the window ,when moving to the next fixture,when going in PREVIOUS nothing strange.
Thanx to all. = )
Tnx for the report, looks like the screen navigation doesn’t monitor the state of the Ctrl-button when page up/down is being pressed, causing double action. Will be fixed in next build
That’s because the processors are also fixtures and, as for fixtures operations while in patch mode, the caches must be rebuilt to update references. This will be improved in a future version.
Simply double click or right click on an (empty) slot and a wizard will pop up where you can select. AFAIK, documentation is in progress (it takes until release candidates for new features and their visuals to be stable enough to start documenting)
Maybe there’s a issue with the show file if it shows input processors on a PC, but not on an NX1, maybe you could upload it to Obsidian Control Systems so we could have a look (because it appears to work on our test).
Overwrite Q Blender doesn’t update Cue count in cuelist directory correctly.
(picture example: 2 Cues in the cuelist but cuelist directory shows 3 cues.)
I haven’t found an update pattern yet.
